Right now I'm doing a pre panel fit test on the car, and getting ready to install the new outer sills.
Should the top of the sill be flat or should it have a slight downward angle? The botton of the door has a slight angle, should they be parallel with each other with this angle?
Right now I have a gap of 1/2" in between the bottom of the door and the top of the sill. Does this sound right, is that enough room to fit the bottom seal on the door? I don't have a new seal at this time.
I have a even door gap all around of 1/8", except at the top were it curves 3/16" Does this sound like the correct gaps?
The door opens fine without any problems even with this narrow gap.
