HJR
I am in the process of installing new main and rod bearings in my 1959 TR3A engine. With the timing chain disconnected, all rods disconnected and the front main and rear main installed with bolts per spec torque with engine assembly grease on the bearings the torque to turn the crank shaft is about 5 ft-lb. Is that ok? When I install the center main bearing with grease and with the bolts to spec torque the torque to turn the crankshaft rises to about 25 ft-lb. The crank shaft end float and thrust washers have been adjusted so end float is .005. Is 25 ft-lb too much? Should I emery cloth with very very fine grit at high spots as revealed by lack of assembly grease at spots on the center bearings? The crank shaft journals appear to be very mirror smooth. The new bearings were from VB and are silver color vs yellow color on the old rod bearings.
