CJD
Your journal looks good to me without polishing. The discoloring is not a problem unless it is an obvious carbon build up. It appears it is not at all, though.
If the crank is out, you can polish it with 600-1200 grit paper...but use a cord to wrap at least one full wrap around the journal to do the polishing so you will not "flatten" a journal. Minimal is the word. It is recommended to polish after a grind to remove the tiny microscopic saw teeth left in the metal after gringing.
John
John
