AweMan
I think I would be having a look at those bearing clearances with some plastiguage
Mainly the main bearings. But .... do the rod bearings as well while you are in there.
Decreases in O.P. due to heat is a pretty good indicator of too much bearing clearance.
A bad filter or even a malfunctioning O.P.R.V. shouldn`t change the O.P. readings very much due to warm up.
Just my honest opinion.
