TR3driver
Great Pumpkin - R.I.P
"nothing gets near 400 degrees, although steel won't loose its temper that low anyway."
"420 is not enough to heat treat steel."
"To alter the grain structure, and thus the temper, you must hold the temp above cherry red for several minutes"
"Randall, you are confusing several different processes."
"Oh you got it off the internet...well then it must be true. Shame I wasted 4 years learning this all wrong."
Oh yeah, I see where you agreed with me right down the line.
And all because I said I prefer not to use heat in this particular case, a safety-critical area that is obviously stressed very close to it's fatigue limit, and an unknown (to me anyway) state of hardening, manufacturing method and steel alloy. I never said it was wrong to do so, only that I prefer to be overly cautious in this case, especially when it's my neck sticking up above the body line. And that it can be done without heat.
The problem, if any, is not so much "loose"-ing the temper as it is creating a boundary where the temper changes. Stresses are increased at such boundaries, because the steel on one side flexes more than the steel on the other. Kind of like the old trick of ripping a phone book in half. And all it takes is for the localized stress to increase beyond the fatigue limit, so the local material starts to fatigue when cornering hard. Actual failure will be many thousands of miles or even hundreds of thousands of miles farther on down the line, likely most people will never drive their cars that far or that hard. (At this point, I probably won't either. I haven't even bothered putting the sway bars back on my current TR3 yet.)
One last point, the blue TR4 in the video I linked to above was built by "uncle jack" Drews, who was not a "bozo" in any sense of the word. He was a very well respected, and very successful Triumph racer, and has probably done more to advance the state of Triumph racing than anyone else short of Kas Kastner. I believe his son Tony was driving it at the time, though. Whether that break had anything to do with Jack's use of heat to separate the hubs, I don't know. Very probably not. I don't care to take the chance since I don't have to.
