These hub caps are really on there! I believe there is a special tool required to remove them without buggering up the caps and/or rims. Does anybody know where I can get one?
<span style="font-size: 11pt">Here's the specs if you want to make your own.
I used a gas welding rig to flatten out the last 3" -3 1/2" so it would fit between the hub cap & the wheel, & also to braze the 2 pc together and lastly to round off the top of the short piece.
I put a dab of silicone seal on the rounded off top piece where it would touch the wheel.
It isn't indicated in the photo but the rounded off tip should extend about 1/2" beyond the last bend in the long piece.
Frank</span>
Let me know if you decide to make up a batch of these tools. I've been looking for one for a while and would also be interested in getting one if you make some up.
