TR2/3/3A TR3 Head Gasket
RedTR3
My tr3 is in the shop again to correct a valve problem. I am going to furnish the mechanic with the head gasket...I have a NOS Payen that is probably 30 years old...would this be preferable to the modern gaskets that are furnished in gasket sets these days?
martx-5
NOS preferable?? A "modern" Payen head gasket is generally considered to be a very good gasket. I have one on my modified TR3 and it hasn't caused any problems. If it's the same construction that they are now using, it should be fine.
BTW, I bought the Payen separately, not in a set.
Geo Hahn
Sounds good to me -- short of physical damage I don't see a reason (either design or aging) that would create a problem with the 30 years on the shelf.
Since the problem being addressed is valves, your old head gasket may be in pretty good shape (and custom-fit to your head too) -- by all means go with the NOS one but consider keeping the old one as an emergency spare.
Those who have noticed I carry a spare head gasket on long road trips think I'm crazy but maybe someday I'll look smart -- it might even benefit one of them. Of course, they may still think I'm crazy.
RedTR3
RedTR3
Art;
Payen no longer makes the tr3 gasket since about 2 years ago...I tried about 10 suppliers and no one has any stock left, either in sets or single.
martx-5
I bought mine about three years ago from British Frame & Engine which still lists Payen AE330. I also have 87mm liners, so maybe the 83mm ones are different. Either way, if they aren't available anymore, that's a shame, because that head gasket has a good reputation.
TR3driver
Great Pumpkin - R.I.P
I asked Ken last year, he doesn't have any more and doesn't know where to get them.
He never was very good at keeping the web site up to date.
RedTR3
RedTR3
That's pretty common; l found that many suppliers show the Payen on their website but if you call them, they really don't have any.
T TR2/3/3A tr3 head gasket Triumph 38
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
Lukens TR2/3/3A TR3 blown head gasket? Triumph 39
RedTR3 TR2/3/3A TR3 Head Gasket [Again] Triumph 4
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
S TR2/3/3A TR3 head is off -- awaiting head gasket Triumph 9
S TR2/3/3A Uggh! TR3 head gasket leak!!! Triumph 9
Got_All_4 TR2/3/3A Blown head gasket TR3 what to do next? Triumph 16
martx-5 TR2/3/3A TR3 Head Gasket Triumph 16
Marvin Gruber TR4/4A TR3/4 head thickness Triumph 7
M TR2/3/3A Tr3 Head Rebuild Triumph 3
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
H TR2/3/3A TR3 head /cam Triumph 4
K TR3/4 Cylinder head temperatures? Racing 1
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
tinman58 TR2/3/3A Removing head studs TR3 Triumph 15
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
S TR2/3/3A tr3 head light switch Triumph 3
K TR2/3/3A Head bolt torque TR3 Triumph 3
H TR2/3/3A TR3 -- Pull the head "while I'm in there . . ." Triumph 9
K TR2/3/3A Internal view of a tr3 control head Triumph 7
mountainman TR2/3/3A TR3 Bright Head Lights Triumph 3
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
Marvin Gruber TR2/3/3A TR3/4 cylinder head differences Triumph 3
newmexTR3 TR2/3/3A tr3 head rear oil leak Triumph 9
T TR2/3/3A TR3 head core plug [freeze plug] Triumph 6
A TR2/3/3A TR3 head welding Triumph 4
Tinkerman TR2/3/3A TR3 Oil filter head, long stud? Triumph 2
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
A TR2/3/3A TR3/4 head crack, can it be welded Triumph 11
K TR2/3/3A Torqing the head again?....rebuilt motor... TR3 Triumph 4
A TR4/4A TR3 / TR4 head crack repair Triumph 3
J TR2/3/3A TR3 control head internal pictures? Triumph 11
C TR2/3/3A TR3 Head Work Triumph 2
C TR2/3/3A TR3 Head Triumph 3
S TR2/3/3A head bolts on a tr3 Triumph 5
MGTF1250Dave TR2/3/3A TR3 Control Head Triumph 4
D TR2/3/3A Control Head [TR3] Rebuild Triumph 2
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
MGTF1250Dave TR2/3/3A TR3 Control Head Help Triumph 9
E TR2/3/3A TR3 Cylinder Head Lubrication Triumph 11
