TR2/3/3A Tr3 gas pedal
sp53
Awhile back we talked about the gas pedal cross shift rod that bolts on the firewall of a tr3. I think it was Geo that suggested the shaft came from the factory straight and that could easily be the case. But before I straighten mine out I am wondering how many straight ones are out there. Please for give me if I miss quoted you Geo.
Sp53
Russ Austin
I'm sure there are a lot of straight one's out there. Mine is not straight and I'm sure 75% of those cars that have had an engine rebuild are not straight. When installing an engine many times the flywheel will hit the the gas pedal shaft.
Don Elliott
And the rear of the engine block will sag downwards and back when you have the gearbox out and this will force a bend into the cross shaft for the gas pedal.
Russ Austin
Don; I think we both have been there and done that.
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
S TR2/3/3A Tr3 gas pedal shaft socket Triumph 7
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
J TR2/3/3A TR3 gas tank mystery Triumph 5
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
S TR2/3/3A TR3 gas filler cap Triumph 1
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
tinman58 TR2/3/3A TR3 gas tank? Triumph 2
T TR2/3/3A TR3 aluminum gas tank on eBay Triumph 4
T TR2/3/3A remove a tr3 gas tank Triumph 7
K TR2/3/3A TR3 gas tank inlet size? Triumph 2
M TR2/3/3A TR3 gas cap question Triumph 4
R TR2/3/3A TR3 gas tank Triumph 13
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
T TR2/3/3A TR3 gas tank vent Triumph 12
S TR2/3/3A tr3 gas gauge calibration resisters Triumph 12
af3683 TR2/3/3A TR3 Trunk Plugs Near Gas Tank Triumph 3
af3683 TR2/3/3A Installing TR3 Millboard Gas Tank Cover Panel Triumph 5
S TR2/3/3A tr3 gas gauge Triumph 5
T TR2/3/3A TR3 gas tanks Triumph 9
mountainman TR2/3/3A Tr3 Gas Additives Triumph 23
K TR2/3/3A 57 TR3 gas tank hold down strap mistery? Triumph 5
S TR2/3/3A One more tr3 gas tank? Triumph 1
S TR2/3/3A late tr3 gas cap? Triumph 5
S TR4/4A late tr3 and tr4 gas caps Triumph 4
S TR2/3/3A Tr3 gas cap vent Triumph 0
S TR2/3/3A tr3 gas tank vent Triumph 3
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
S TR2/3/3A gas tank in a 1961 tr3 Triumph 12
S TR2/3/3A Tr3 gas tank again Triumph 3
S TR2/3/3A Tr3 gas tanks Triumph 7
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
tinman58 TR2/3/3A Another TR3 gas tank ? Triumph 3
mountainman TR2/3/3A TR3 Gas Tank Question Triumph 7
H TR2/3/3A TR3- installing gas tank = nightmare Triumph 18
S TR2/3/3A gas gauge TR3 Triumph 7
J TR2/3/3A gas leak on a TR3 Triumph 4
martx-5 TR2/3/3A TR3 Gas Tank Installation Triumph 5
RedTR3 TR2/3/3A TR3 - Gas odor and poor mileage Triumph 5
S TR2/3/3A Tr3 gas tank repair Triumph 9
J TR2/3/3A tr3 and unleaded gas Triumph 9
martx-5 TR2/3/3A TR3 Gas Tank Triumph 3
S TR2/3/3A TR3 Gas Mileage Triumph 9
D TR2/3/3A TR3 gas gage Triumph 2
