57 tr3 small mouth. has about 7 miles on it. had some transmission troubles, had to remove it, get it fixed, and put it back in. that took about 3 months. fuel pump seems to have failed. no gas to carbs. put in new one, but still same problem. gas gets to the glass bowl, and if you prime the pump gas comes out. we blew out the line between the pump and the carbs and its clear.
did i perhaps not get the lever under the cam when i installed it? is there any way to test that or have i done that?
is there something else? tank is 1/2 full and as i said, gas is definitely getting to the pump. checked the cutoff valve; it is open.
