TR2/3/3A TR3 Engine Ground Strap
martx-5
I looked at Moss online and the engine ground strap (down by the engine mount) is N/A. They list availability for the TR4. Can that one be used?? Or, does someone else have the correct one available??
Stig
I've taken a bunch of 3's and 4's apart, as I remember its the same bonding strap for both. Braided steel (round), about 8 inches long, with 90 degree ring terminals at each end.
TR3driver
Great Pumpkin - R.I.P
Interesting. My TR2/3 SPC has 3 different ground straps listed. The Stanpart number was 501495 to TS18912, then 303006 to TS60000, then 509271 from TS60001 onwards (or at least until the end of where this book covers).
No idea what the differences were, but I see that TRF has the last one, 509271 cross referenced to the same Lucas P/N as the factory 131116 listed for TR4.
But the one that TS13371 is wearing matches Stig's description, so I'm pretty sure he's right about the TR4 part being usable on all the TR2-3.
Tinkerman
Art, what I have is a Moss number 736-080 which they show as NLA grounding strap, which I will use for my car BUT I can send you pictures and dimensions and I also have an extra set of helmet cable ends of the proper screw type configuration.
These are extras that I bought on ebay THOSE are the NOS Lucas units.
The Ground end is a ring terminal as described by Stig. Thay can be had at any competant starter/alternator shop. The cable would have to be soldered in, again they should be able to do that for you. And they should have the cable.
The helmet ends are yours for the postage if you can use them.
Now if you can tell me where I put my new generator, that would really help!
Email or PM me if they would work for you.
Cheers, Tinkerman
Stig
You are thinking of the battery ground wire. I'm talking about the engine bonding strap located on the front left engine behind the timing cover.
TR3driver
Problem is, that's a <span style="font-weight: bold">battery </span>ground strap, while Art was asking about the <span style="font-weight: bold">engine </span>ground strap. Eg, Moss 736-030
:frown:
angelfj1
Stig: I don't think that will work.
try this
https://www.britishcarforum.com/bcforum/u...e_to#Post426463
If this is the part you need, as I did recently, the only company that I could find with the correct terminations was British Wiring. These are made of tinned copper braided wire and properly terminated with a lug that is at a right angle to the cable. The big three will supply a cable that is terminated with a straight lug which is not correct.
Tinkerman
Well I sure learned something today. Didn't even know about the earthing strap, much less where it went DUUUUHH.
Thanks for the info
Tinkerman the educated!
TR3driver
Well, at least you aren't asking why your choke cable is smoking !
:devilgrin:
Tinkerman
Called British Wiring today and ordered the proper earthing strap for my car.
Ya gotta love the BCF!!!!!!!!!!!!!!!!!!!!
Tinkerman
Tinkerman
Ordered one from British Wiring. Came in Thursday. It's perfect.
Yea! Got another one covered.
Tinkerman
T TR2/3/3A TR3 engine ground Triumph 9
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
Moosca TR2/3/3A "56 TR3 Engine Verification Triumph 17
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
O TR2/3/3A TR3 engine removal Triumph 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
A TR2/3/3A TR3 engine removal Triumph 9
