TR2/3/3A tr3 dash brackets
sp53
Hi all does anyone know what the little clip is for that is on the back of the dash brackets on a 61 tr3. I talked to a tr guru once and me maintained that they are for putting a clip on to hold the water temp tube in place? The picture is kinda ok the bracket is in the front.
Steve
martx-5
I believe that's for the bracket that helps hold up the glove box at the rear of the box.
Edit: There's another bracket for the choke cable, but that's more in the center IIRC.
Moseso
If, by "back of the dash brackets," you mean the end away from the dash, then I agree with Art. It's bent -- it should be at a right angle -- but that's what it is.
If I were to refer to this part, I would call it the "front" of the bracket, as it is towards the front of the car. It's a good convention. "Front" = front of the car -- always.
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
Kleykamp TR2/3/3A Vinyl covering on dash on TR3 Triumph 7
J TR2/3/3A Basket weave dash on TR3 ???? When Triumph 21
doc50 TR2/3/3A TR3 Dash Clips Triumph 6
Lukens TR2/3/3A Wood TR3 dash Triumph 10
K TR2/3/3A TR3 red-light on dash again Triumph 5
Russ Austin TR2/3/3A TR3 Dash Clips! Triumph 2
O TR2/3/3A TR3 Dash Bulbs Triumph 13
K TR2/3/3A TR3 Red dash light stays on? Triumph 4
K TR2/3/3A Picture of TR3 Dash Gauge Layout Triumph 2
K TR2/3/3A TR3 Dash lights:Conversion to green bulbs? Triumph 3
S TR2/3/3A Tr3 dash rail capping Triumph 4
S TR2/3/3A dash light variable resistance tr3 Triumph 8
ekamm TR2/3/3A Tr3 dash removal help Triumph 8
S TR2/3/3A large /main dash on 61 tr3 Triumph 0
Russ Austin TR2/3/3A Recovering Dash TR3 Triumph 11
tinman58 TR2/3/3A Wood pieces under dash of TR3 Triumph 12
GBRandy TR2/3/3A TR3 Dash Pots Triumph 7
martx-5 TR2/3/3A TR3 Dash Installation Triumph 7
CCURTISS TR2/3/3A TR3 Dash Knob Question? Triumph 2
T TR2/3/3A TR3 dash wrinkled Triumph 6
M TR2/3/3A TR3 Dash Recovering Triumph 24
Tinkerman TR2/3/3A Removing Fabric From TR3 Dash Panel Triumph 7
S TR2/3/3A Wiring for Dash Lights - TR3 Triumph 6
martx-5 TR2/3/3A TR3 Dash [Facia] Triumph 12
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
