M
Member 10617
Sorry... but my car was painted by the former owner and I don't know what paint he used.
Just before I purchased the car, one of the fenders sustained some damage that required repair and re-painting. In that case, the shop used Du Pont Chroma Premier Single Stage paint. I have a small can for touch-up but the Code is blank (no number given) and the Color is simply "white." But this color duplicated the color of the rest of the car ALMOST precisely (a little bit lighter in certain light).
Du Pont Chroma Premier Single Stage paint requires an activator. It may be hard to obtain if you are going to do the work youself because Du Pont says "For industrial use only by professional, trained painters. Not for sale to or use by the general public." The small can I purchased from an auto paint supplier is for "touch-up" only.
Some of these paints are so hazardous to health, etc., that if you are going to paint your car, I would strongly suggest considering having a professional (in a paint shop) do it for you. Just my two cents worth...
