TR2/3/3A TR3 Coil + Heat = Misfiring and Sputtering?
karls59tr
Bronze
Is it possible for the coil to become so hot ,being mounted against the block and all, that it would cause ignition problems?
Re: TR3 Coil + Heat = Misfiring and Sputtering?
Yes, but mounting is not the problem. Be sure the 2 small wires are on the correct posts.
So are you having stumbling etc, or just asking if it could lead to that?
If all is in good shape and working properly, the coil shouldn't get hot enough to be a problem before the engine is boiling over. But various faults can cause the coil to get hot enough to malfunction. Sometimes you get other indications too, like it leaking oil.
Actually I took the 3 out for a run after a 2 year layover. Prior to the layover I was having issues with stumbling,misfire and sputtering.Could'nt make out if it was a fuel issue or ignition. I sent the distributor out to Advance for a rebuild and advance curve to match the street cam I had installed with the engine rebuild. Well the car ran great....a joy to drive ...pulled strong in all gears....no misfire etc. After driving the car all morning I unexpectedly started experiencing the same symptoms as previous! So I'm thinking its a carb issue. Also pevious to the layover I leaned out the carbs 2 flats as the plugs had been carboned up. I'll pull the plugs this morning and see if they are carboned up again. Also I changed out the fuel filter, drained the tank and put fresh gas in prior to the run. Might have to go leaner yet?
It sure sounds a lot like what I went through with my TR6. The coil should get warm but it shouldn't get so hot that you really can't touch it. The hotter my coil got the worse the car ran with regard to backfires, stumbles etc. After a 5 mile drive, touching the coil could burn you hand.
Before you start fooling around with the carbs, make sure the coil isn't wired wrong or that it's the wrong coil.
Loose connection at the coil and an intermittment break in the wire (white w/ black tracer) from the coil to the distributor are also on the list of things that can go wrong here.
