Marvin Gruber
Got a better look at the door tonight. Believe someone has built up your door latch area. Where that hammer when you need it.
Marv
Marv
Tr3aguy said:I believe that the first latching point you are referring to is a safety catch but not where the lock should stop.....in order for the door to fully close it needs the pass the second lip and latch behind that. It will mate up with the ramp shape of the lock guide and strike plate. So something is stopping from traveling that far in......With the strike off of the car will it fully travel into the lock mechanism to reach the second lip?
tinman58 said:I belive that your problem is solved. But be aware that I have done a TR3 restoration three times in the last 30 years and that is nothing to be ashamed of. Its fixed right? Just make sure that you install the windshield wiper mechinism under the scuttle first, before you install the wiring, heater, gauges ect. Just a heads up!!
