Darrell_Walker
DNK said:Flaps??
Friendly Local Auto Parts Store
DNK said:Flaps??
DNK said:Baxter's ,not familiar with that store and you live in the same state.
Is that an O'Reilly's sub?
I'm not Geo, but maybe this will help: First, install all the bolts finger-tight. Then torque the center bolt on the LH side, followed by the center bolt on the RH side. Now the bolt just forward of center on the LH side, followed by it's mate on the RH side. Then the bolt just rear of center on the LH side, followed by it's mate on the RH side. Lather, rinse, repeat.LexTR3 said:However, I'm not sure I understand the procedure you recommend for tightening the bolts: "back and forth working from the center of the pan outward". I just can't picture it in my mind. Can you be a little more specific?
LexTR3 said:...I'll see what I can do with the oddball bolts. For the shorter ones, perhaps I can take a regular bolt and add a couple of washers until I get the right length, as I suspect the shop guys did. I may have to "wing" it on the longer one, unless I am lucky enough to find one...
Fully threaded ? The ones I've seen have unthreaded shanks. Oh, and just for clarity, the pan bolts are all 18 tpi (which is probably what you meant).Geo Hahn said:Got a 1-1/4" (5/16 28 tpi) bolt just today at Ace hardware - about 25 cents.
Hopefully this is obvious, but they are all available from TRF.LexTR3 said:I may have to "wing" it on the longer one, unless I am lucky enough to find one.
TR3driver said:Fully threaded ? The ones I've seen have unthreaded shanks. Oh, and just for clarity, the pan bolts are all 18 tpi (which is probably what you meant).Geo Hahn said:Got a 1-1/4" (5/16 28 tpi) bolt just today at Ace hardware - about 25 cents.
I assume you are talking about the classic problem, where the screen wires break right at the surface of the solder joint between the screen and the end of the pickup tube ?karls59tr said:While the oil pan is off ,does anyone know of a good method to repair a hole in the oil pump screen? Seems every screen I've seen has a bole worn in it from vibration!
