TR5/TR250 TR250 "gives a little cough" at times
RobT
So I've been enjoying the nice weather we have been having in Eastern Mass the last couple of days and putting a few miles on the TR.
Its going really well, the suspension upgrades over the winter make it even more fun to drive.
The only problem is that, under load at low revs (<2k) it gives a little "cough" and splutter, hesitates and then once I am above 2K revs, of it goes.
Does not feel like ignition (but could be), and the carbs (triple ZSs)are recently re-built, so not sure what is going on.
Here is my set-up:
Point-less electronic ignition
Triple ZSs with auto transmission fluid in the dash pots (as recommended by Joe Curto, who rebult them)
Goodparts "mild" cam
Stock distributor, with both vacuume retard and advance disconnected
Timing at 10deg BTDC
Compression between 180-190 lb on all cylinders
I have a couple of suspisions:
1) I need to reconnect the vaccume advance on the dizzy
2) Different oil in the carb dash-pots (lighter or heaver?)
3) Vacuume leak
Or it could be something simple like dirty plugs.
So can antone help me out with any suggestions they may have before I start in taking things apart etc?
Thanks in advance for the advice.
Rob.
Andy Blackley
Rob: Try the heavier oil first. ATF is too thin IMHO. I use motor oil.
Consider reattaching the vaccuum advance (only).
Do you know which metering needle you are using in the carbs?
BTW which plugs are you using?
RobT
RobT
Thanks Andy - I will hook-up the vacuume advance. This was going to be my first step.
Any thoughts on the grade of motor oil to use? Is 20W50 too heavy? Perhaps 10W30?
Not sure what the needls are - is there any way to tell?
As for plugs - I am using the Bosch Platinum plugs from VB.
Thanks again,
Rob.
Andy Blackley
I use 20W50, especially in the summer. ATF is OK in the deep winter, but I havent driven an LBC through the heck of a nortnern Ohio winter since 1990. Now I drive a BBT.
Which carbs are you using? The only way to check the needle is to remove one and look a for the markings on the shank.
I use good old Champion UN-12Ys.
G
Hey Rob,
Darn if I don't experience the same exact thing with my car.
We have similar setups. The only real difference is I am running basically stock ignition although I do have the hotter Sport coil and fat low resistance plug wires with cold Champions. I will get a little cough or burp at low highway speeds, with a very mild throttle. I have checked every possible option for correcting this, save reconnecting my vacumn advance. I don't really see what this could do. I am beginning to wonder if this isn't a little quirk of the trips setup. It seems to go away after some time, perhaps after half an hour or so of cruising. It can't be a fuel problem as it seems to come and go with such quickness. There is way too much fuel in the system for such a burp to occur. It almost seems electrical in nature, or timing. I am at a loss as to what the issue could be.
Bill
bobh
Take a look at the PDF on the site listed below. Even though it is based on Volvos there is some very good information. Particularly the section on acceleration on page 2-39. Note the mention of ATF
My guess is that when you hit the gas pedal to accelerate you have a momentary rich condition. The engine can't quite handle the extra gas from the three carb setup. One or two hiccups and the engine starts to get enough air to digest all of the gas.
I've experienced a similar situation on a motor cycle with a carb and an accelerator pump. I set the pump to it's richest setting. Below 3500 rpm the bike would cough due to the extra squirt of fuel then take off like a missle. Above 3500 it digested the gas immediately and took off. Granted the engine design and speeds are different that the TR, but the symptoms sound familiar.
One of the Healey guys, GregW , put 3 Mikunis on his 3000. They have accelerator pumps. Although they are different than Strombergs, the momentary rich condition may be a common issue. He said it took a while to sort the carbs. He may have some ideas.
https://www.dctra.org/files/carb.pdf
DougF
I don't think it would be the oil. I'm not running your configuration, but do run Marvel Mystery Oil in the dashpots with no problems.
vettedog72
Reconnect the vacuum line to the distributor and part of (if not all) of your problem should go away. The mecanical advance is for WOT; you can benefit from the vacumm advance system with anything less than WOT.
Andy Blackley
I think the problem is a momentary too lean condition. If the carb piston moves upward too rapidly the carb actually leans out until RPMs increase.
A simple engineering formula for flow is Q=V*A. Q= flow rate, cubic feet per min., a function of engine RPM; V= velocity, A= the cross sectional area of the carb opening.
At a rapid throttle opening the piston rises, and if undamped by oil or a stiffer spring, the cross sectional area increases faster than the RPM. Therefore the velocity will decrease until the RPMs increase. The loss of velocity results in less negative pressure over the jet bridge (venturi effect), which means less fuel is drawn upwards through the jet, even though the jet opening is larger.
This momentarily results in a lean condition, hence the stumble.
Having three carbs doesn't matter, as the carbs operate in proportion to the flow rate.
Try a simple experiment. Next time you feel the hesitation, try repeating the condition again with the choke pulled out slightly to enrichen the mixture. If the hestitation goes you found the problem.
The cure ranges from simply using heavier oil in the dashpot; a stiffer spring (red)in the air valve (piston); or a richer metering needle.
Heres a link to one of a jillion such articles: https://www.jetlink.net/~okayfine/su/damper.html
RobT
RobT
Thanks guys for all the great advice.
Last night I reconnected the vacuume advance and replaced the auto trans oil in the dash pots with 20W50 motor oil.
Another glourious morning today, so drove the TR to work (the most direct route from home to the office is about 3 miles, but on a nice day in the TR, I can do it in 15 miles!)
Well the car is much happier with the changes, still a little stumble from a stop, but not nearly what it was. While I was working on the carbs last night, I also leaned out the mixture a tad, which given what Andy says above may have been a mistake. Also noticed a little pinging too. So I'll bring the mixture back up again and see how she runs.
Once again, thanks for all your help!
vettedog72
Rob:
If you have a bit of ping well off of max RPM, I would turn the distributor to retard the timing a minute amount at the time until there is no ping. If you want the highest performance from the engine, you can adjust the timing more aggressively.
RobT
RobT
Thanks "vettedog". I'll give that a try too.
BTW - What is the best way to adjust mixture?
Perhaps I should start a different thread on this issue, as I'm sure there are many an opinion.
I've always done it pretty much by trial-and-error. I have a Gunst colour-tune, but never had much sucess with it, and with a triple-carb set-up, doing it by ear is pretty much darn near impossible. Any favorate "tricks" folks have?
Rob.
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
T TR5/TR250 Original TR250 sun visors Triumph 0
Marvin Gruber TR5/TR250 TR250 Alternator Triumph 13
glemon TR5/TR250 TR250 Prototype Triumph 10
flylear45 TR5/TR250 TR250 resto project log Triumph 12
M TR5/TR250 No spark on TR250 Triumph 17
David Townsend TR5/TR250 New TR250 Limited Edition Print Triumph 0
H TR5/TR250 TR250 rebuild question Triumph 3
