TR2/3/3A TR2 door help!
Southwarks
Afternoon all. So the passenger internal door cable has become separated from the bolt end and the door is closed.
Any ideas how to get the door open without removing the seat and door card?
Many thanks
I had to go back through my pictures to see what you are dealing with. It looks like you should be able to reach a screw driver into the latch slot to manipulate the latch arm. You are trying to catch the rear and pry it forward. It may also be possible to reach in through the door pocket, if the pocket has an open top.
Thanks, had to get a screwdriver and a tough piece of plastic to lever the bolt back in the door jam. But it's open now, just need to fix the mechanism.
