TR2/3/3A TR2 Coil choices
2long
I'm looking to replace my coil, for my original TR2 distributor set up. TRF has a Lucas coil, a Lucas Sport coil, and a Petronix coil that looks like it involves a conversion kit. I recall some concerns that new coils are hit and miss, but if anyone has recent experience I would appreciate it. I want to keep things as stock as possible, so I am not inclined to do a conversion. Same question for replacement condenser and ignition parts - what is the best quality one to use? I have some old NOS lucas items, but I would like some input on the the quality of TRF or Moss replacement parts.
Dan
TR3driver
Great Pumpkin - R.I.P
I got a Lucas Sports coil from TRF at the 2009 Triumphest, that lasted less than a year. Not fun, especially since it died while I was on the freeway in rush hour traffic on my way to a TR club meeting. I grabbed a 1.5 ohm Pertronix coil that I had on hand (for a Stag) and used that with an external ballast resistor for several years. That worked fine, but I eventually bought a 3 ohm Pertronix coil which is what's on there now, just to clean up the temporary resistor installation. (It also works fine, so far at least.)
If you have an original type coil wire, you'll need to change it to a plug-in type terminal for the Pertronix, instead of the original screw-in. Easy enough to do, just cut off the original tip of the wire (saving the brass washer that is soldered to the wire), and remove the nut. Any parts store can sell you a clip & boot to fit the new coil (if they didn't come with it). Slide the boot on, then strip roughly 1/8" of the insulation, fold the center conductor over and install the clip.
The Pertronix already had screw terminals for the low tension connections, so just undo the nuts, remove the quick connects and drop the ring terminals into place.
It's also slightly smaller diameter than the original, so I used a section of aluminum beer can as a spacer. The thin aluminum cut easily with my pocket knife, so that was trivial.
Don't be too surprised if 3 ohm coils are hard to find in the local stores. I didn't bother looking this time, but years ago I checked several places and no one had them. Practically all American cars used external ballast resistors and 1.5 ohm coils. Also be careful about the "12 volt" designation, as some 1.5 ohm coils are marked "12 volt, ballast required". You can certainly use one of them, but you'll want to be sure to supply the ballast it needs (otherwise the points will burn up in just a few hundred miles BTDT). The store should have the ballast, but they may not know what it is. If not, ask for the ballast resistor for a 66 Dodge Dart with a 225 slant six :smile:
Geo Hahn
I too had a couple of Lucas Sport coil failures some years back - but more recent ones have lasted for several years now on the TRs. The fails had a white top on a gold case. The more recent ones have a black top on a gold case.
No, I don't think the color of the top was the problem
but if you get one with a black top it is likely a newer manufacture than one with a white top.
TR3driver
I found an old photo : The one that failed for me had a black top and gold case.
Geo Hahn
So much for color as an indicator... unless you can find one with the terra cotta top and Buck Rogers/Art Deco design.
That one is 42 years old and still working well (knock wood).
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
M General Tech TR2 Slave cylinder Triumph 0
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
