Towing a bugeye
Rut
I'm sure this has been discussed before and I did an advanced search before posting this question. I would like to add a tow 'bracket' to my bugeye and thought the original front bumper mounts might work well. I want to install a front tilt kit as well. Has anyone done this and can they share the pros and cons of a set-up like this as well as towing in general? I don't want to use a tow dolly or trailor and will be towing about 250 miles one way. Thanks, Rut
Rut,
I'm sure it can be done, but the biggest problem I see is that the two bolt holes on each side for the bumper brackets are about the only holes available to mount a tow bar, and that is where the tilt bonnet mounts to. Are you going to mount the bonnet later, or will it be on when you are towing? While you may not want to use a tow dolly, or a trailer, that is what I would recommend. Also, depends if this is a regular trip, or just one-off. Cheers, Sorry I can't be of much help here.
Scott in CA
Thanks, I was hoping to have a bracket made that rotates with the tilt assembly. My main concern is parking my trailor or dolly. I'll be towing or transporting the bugeye to the coast and the condo association does not allow storage of either in the parking lot or the boat storage yard. I would have to rent an off site location for storage and it just complicates matters. My thought was to take either an existing design of a front tilt and add a bracket that bolts to the tilt mechanism or have one designed from scratch. The assembly could look similar to a 'nerf' bar, but with holes for a custom tow bar. Thoughts?
Thanks, Rut
Rut,
My Bugeye has both a forward tilt bonnet and a tow bar bracket. However, the tow bar mounts to a bracket welded beneath the two main front frame rails not the tilt brackets. Send me a PM and I'll see if I can round up some pictures for you if you like.
JPF
Thanks, PM sent.
You will need to disconnect the drive shaft to tow (but you probably knew that)
They make some tow dolleys that you can pull pins on and fold up some and not take as much space. I have seen them but I can't give you a brand name. The other option is take a regular tow dolley and make yourself some rope hoists in the garage and hoist it up to the ceiling and park the spridget in under it with plenty of room. I have actually been contemplating something like this for fitting two spridgets in one garage bay.
JP, is that the case? I'm looking for a simple way to do this and the drive shaft doesn't do it for me. If I use a dolly and take the wrath of the communal xxx, can I put it under the back wheels? It might be easier to put a hydraulic tilt bed on my PU. Any ideas?
Thanks, Rut
Thanks, Rut
Yes, there isn't enough oil moving around the gearbox though the shaft is turning. You could tow it backwards I suppose - though not with wire wheels. You might think about renting a Uhaul dolly one way - would be a little more expensive but a lot more convenient.
Or, find someone who live close by who could store the trailer/dolly.
I think a tilt bed would be awesome, but only because having a transporter is a dream.
JP, this would be a regular thing and I want it as simple as possible. We travel back and forth about every 3 to 4 weeks and I'm looking for a simple solution. Would a different make of rear end work better while towing? It's a pita having to deal with a communal living situation and the regulations that go along with it. I guess an aluminum tow dolly could go in the back of the PU if it had to after I get there. Any thoughts outside the box?
Thanks again, Rut
Tis not the rear end is the tranny. Unbolt the shaft at the rear end (four bolts) tie the shaft up with a coathanger, and tow away.
No wire wheels on this one. Jack, I'm trying to avoid things like that. I want to figure out a way to hook it up and go and avoid the storage issues a trailer or dolly present. If you can't tow it without disconnecting the drive shaft it may just stay home.
Thanks, Rut
Jack makes a good point, the simplest and cheapest solution would be a tow bar, and either 2 ramps or 2 jackstands at either end of the trip.
The simplest and not quite cheapest would be a tow bar and a quick trip to a transmission shop at each end of the trip.
Just took some pictures on the setup here. Still have some over spray to paint. lol
tow bar for a VW. 1" x2" channel bolted across the front with tabs attached for the bar pins. No tilting the front end with the tow bar attached.
And one from the top side.
The brackets were bolted on using the 'Bumper' holes in the front extensions, then the bar was welded to the brackets.
Completely removeable!! :thumbsup:
Steve
:driving:
Lee, that looks perfect! Can you pull your car without disconnecting the driveshaft? I know that's counter to the advice I've been given and I do want to know if it's possible without causing harm.
Thanks, Rut
