Tool Recommendation
tmcarthur
I need to replace my rear axle pinion seal, and I need a special tool to keep the flange from turning as I loosen the retaining nut. In the service parts catalog, I think it's called the "wrench, bevel pinion flange" and p/n 18G84A. Anybody got one of these or a suitable alternative tool?
Thanks.
Terry McArthur
59 BE
51 TD
When I did the same job I simply put a bolt through one of the pinion holes with a link of chain and a nut. Then I ran the chain over to one of the mounting nuts and secured it. This keeps the flange from turning as you loosen the nut.
Hope I described it good enough; if I can find a pic I'll post it.
If the chain doesn't work, an impact wrench will pop it right off.
I used a piece of bar stock and drilled 2 holes to line up with 2 of the U joint mounting holes. You will want something pretty secure when tightening it since you will not want to change the preload ANY or you will ruin your diff.
Kurt.
Thanks Kurt,
I like your suggestion about drilling a piece of bar stock. Also, thanks for the warning about preload. The shop manual says the torque on the retaining nut should be 140 foot pounds. Before I go much further, I better make sure my torque wrench can go that high.
Thanks Kurt,
IIRC the 140 lbs was for initial construction - I don't think you need to go that high to replace the seal.
Agree with JP....just don't exceed 140...or for safety, don't get too close.
Kurt.
