Tool Recommendation
tmcarthur
Member
I need to replace my rear axle pinion seal, and I need a special tool to keep the flange from turning as I loosen the retaining nut. In the service parts catalog, I think it's called the "wrench, bevel pinion flange" and p/n 18G84A. Anybody got one of these or a suitable alternative tool?
Thanks.
Terry McArthur
59 BE
51 TD
Gliderman8
When I did the same job I simply put a bolt through one of the pinion holes with a link of chain and a nut. Then I ran the chain over to one of the mounting nuts and secured it. This keeps the flange from turning as you loosen the nut.
Hope I described it good enough; if I can find a pic I'll post it.
Keith_M
If the chain doesn't work, an impact wrench will pop it right off.
nomad
I used a piece of bar stock and drilled 2 holes to line up with 2 of the U joint mounting holes. You will want something pretty secure when tightening it since you will not want to change the preload ANY or you will ruin your diff.
Kurt.
tmcarthur
tmcarthur
Member
Thanks Kurt,
I like your suggestion about drilling a piece of bar stock. Also, thanks for the warning about preload. The shop manual says the torque on the retaining nut should be 140 foot pounds. Before I go much further, I better make sure my torque wrench can go that high.
JPSmit
Thanks Kurt,
IIRC the 140 lbs was for initial construction - I don't think you need to go that high to replace the seal.
nomad
Agree with JP....just don't exceed 140...or for safety, don't get too close.
Kurt.
steveg At last - inexpensive double crimp tool Restoration & Tools 3
Basil Multi-Tool Scraper/ Utility knife Restoration & Tools 0
Basil Now THIS is a tool box Restoration & Tools 6
drooartz The latest tool addition to the shop Restoration & Tools 25
JPSmit Tool identification quiz Restoration & Tools 16
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
JPSmit what's this tool? Restoration & Tools 8
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
H name and address of Jag tool seller located in Chambersburg pa Jaguar 3
I TR6 Chrome bezel removal tool? Knob removal? Triumph 6
N Tool Rolls and Pouches Austin Healey 14
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
TomMull Knock Off Tool Restoration & Tools 6
K BMC Supplemental Tool Kit Bags - Reproductions made anywhere? Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
1 MGB MGB tool kit MG 18
D Modified carb sync tool. Austin Healey 11
D Eastwood Surface conditioning tool Restoration & Tools 18
D tool roll Austin Healey 2
M Tool Advice Sought Austin Healey 3
steveg Carb float setting tool Austin Healey 11
H useless carb balance tool Austin Healey 25
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
TomMull bubble flare tool Restoration & Tools 4
TomMull Another tool score? Restoration & Tools 6
PC latest tool score Restoration & Tools 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
Michael Oritt SU reaming tool needed Austin Healey 7
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
Rut Diff plug tool Spridgets 7
Nelson My new toy/tool Spridgets 3
S TR2/3/3A the 9/16 & ½ tube socket for the tool kit Triumph 13
drooartz Brake flaring tool Restoration & Tools 8
Brinkerhoff TR4/4A TR4A tool kit Triumph 0
2billydavies TR2/3/3A Question about size of Clutch Alignment Tool Triumph 9
Editor_Reid Tool Kit ID Jaguar 7
trotti Simple tool for steering box adjustment Austin Healey 5
Vila TR4/4A Looking for TR4 Tool Triumph 9
PC next tool hunt Restoration & Tools 0
T TR2/3/3A What is best tool, and best method, for widening gaps on TR3A grille? Triumph 21
PC latest tool hunt Restoration & Tools 15
J Got a new tool for Xmas, tested it this week Restoration & Tools 5
JPSmit New Tool - of sorts Restoration & Tools 5
TomMull caliper piston tool Restoration & Tools 11
S BJ8 Tool Set and Roll Austin Healey 4
A NORTHERN TOOL - Ranger QuickJack Portable Lift Restoration & Tools 3
L A good tool roll Austin Healey 9
Boggsy64 MGB Wise tool investment - if you can find one MG 8
