jlaird
Put on your thinking caps. Added a washer, thicker, at the top end of the jet chamber on the H1s I have. That effectively stoped the fuel leaks as the chamber is now tighter in the assembly. It also effectively shortened the jet tubes.
Now I can not get the idle below 1600. Do I drop the needles the same distance as the new washers thickness over and above the thickness of the old ones to get the needle to go into the jet all the way to the idle step portion???????
Seem reasonable to you folks??
Hi Guest!
