Today's Project-Harley Muffler
It all depends on whether or not the baffles / screen are still in place or not. The bulley shaped muffler is definitely more sporty and has a great tone. I tried several different Harley Muffler types and some made Bugsy sound like a rice rocket with a realy, really obnoxious loud fart sound. The bullet shape as Steve got, I have the same type with a straight through pipe, no baffle to plug. A couple of adapters were all that was needed to connect to the stock pipe. And a hanger from the stock muffler lount and it was done. I did tack weld hte adapters together as U bolt did not get them tight enough and htey kept coming loose. No problems since a coule of quick tack welds. No welds, $20 at local muffler shop or donuts.
Sorry that Pic is real hard to see but no extra baffles to plug that's the one you want. Here it is installed.
From the rear
Wrong file hold on,
Ben, it sounded very mellow compared to the stock one I had until I drilled out the baffle. Now it doesn't sound much better. I was afraid it had too much back pressure with the baffle, but I'm not sure. They are cheap and plentiful, so you might want to experiment some.
