Toasted O/D solenoid
oxford
Hi everyone
I have burned out the new solenoid on my BN4 overdrive. I suspect that it wasn't adjusted properly and the points to the secondary circuit were not opening. Either that or it's faulty. I'll put a fuse in the circuit; but, can any one explain where to attach a multi-meter to check the amperage drop when the solenoid engages?
Thanks
Matthew
A MULTI METER WILL REQUIRE THAT THE AMPERAGE SCALE BE USED AND IT MUST BE Installed IN SERIES WITH THE solenoid POWER LINE. The meter may jump initially then show a steady state 1 Ampere current.
However, this is not the best method to use.
Preferably a scope will show the initial transient's peak voltage and its demise if the holding circuit is properly contacted.
I think you can get a Meter that measures amps from HF that will give you an amp measurement that clips on the wire.
Matthew:
SCOPE= Ocilloscope
Clamp on ammeters probably will not respond to the initial transient current but if it shows a constant 1 ampere flow you are prolly good to go.
Conversely, a steady state higher current indication will say holding circuit not engaged.
Also See: [h=3]fused OD solenoid Below[/h]
Adjusting the arm is critical to the life of the solenoid. That is why you need an amp meter. My OD runs sweet now. (I hope for another 54 years)
