Hap Waldrop
Hey guys, for you gearheaded performance types and folks who may already have these roller rocker arms on your engine. I wrote this up in the racing section, but thought it needed to be added here.
Ok, the best ang for the buck for the A series 1275 in the way fo roller rocker arms are the Mini Spares Titan 1.5 roller tip roacker amr assembly, it a way better set u than the Harland Sharp set up and the 1.5 is a boost in ratio which is boost in camlift. Here's the deal with roacker arms, all rocker arms, roler or not, they move in a arc mtion and when they do they lose valve lift at the end of the lift stroke. In the case of the 1.5 Titan, if the shaft hiehgt can be raised a bit you can get some of that lost lift back.
My friend has benn building a stupidly trick (I mean that in a good way) 1380 street motor, and this motor has the SPV-3 cam whioch is about as radical as I would suggest for the street, and the 1.5 Titan roller rocker arm assembly. Now to get your "perfect" vlave lift, you would calculate camshaft lift x racker ratio - valve lash and that would be what you would get in a perfect world for vlave lift, well thats not the way it works most of the time. When my friend ran these number he was .050" short of his "perfect" valve lift, and this is when he called me for help. I suggested he shim the pedestals and see what he got, for a simple test he found some washers that were .125" thick, and just stuck them under the center of the pedestal for this test. The results were very good, not only did the rocker arm angle get batter, so did the pushrod angle and the adajustment hardware setting as well, and he gained .025" of his lost valve lift back.
When shimming the pedestal, there are many limiting factor involved, valve cover clearence, head stud lenght, so naturally on a given engine comprmises have to be made, in the cae of .125" shim here, that put him at the end of his head stud length, anymore shim thickness and he would need longer head studs, so this will be thickess shim we can run on this engine, but you can see form the second photo where the adjustment hardwar position had change and the rocker arm angle and pushord angle all for the better as well, and to add to that .025" lost valve lift was gained back.
Now he will need to make .125" shims from the a template pattern from the bottom of the Titan pedestals, complete with oiling hle for the oiling pedestal. The first picute show the Titan 1.5 with no shim, and the second photo show with the "test" washer .125" shim.
Hi Guest!
