vping said:Try contacting Jeff at https://www.advanceddistributors.com/. real nice & helpful. There is a curve worksheet to fill out & send to him for your needs & his prices are good. I just sent my TD dizzy out on Monday but I'm hoping it can be saved as it was a mess.
Rick, do yourself a favor and contact Jeff at Advanced Distributors. Tell him what you have and he'll set up the proper dizzy, with the right numbers, just for your engine. You don't even have to send him a core. He will also give you the benefits or pitfalls between points and electronic ignition on your setup. In some cases, points are better. I personally would not put electronic ignition in my car. It ran 30 odd years with points and I'm sure it will run 30 more. Jeff will recurve the dizzy just for your engine for max. performance. As I said in a previous post, after installing a rebuilt dizzy from Jeff, my engine runs better than it ever did since I've had it and I bought it over 20 years ago.JMHO. PJ
Hi Guest!
