Someone suggested the Supplementary Air Valve is causing the
noise. Does noisy indicate imminent failure? I can't hear it
while driving. Only with the bonnet up and my head under the
hood. Could this be responsible for a FF 44 code.
The FF44 code refers to the O2 sensor failure. In the parts manual assembly drawing of the O2 sensor, the same page shows the power resistor. What is the relationship between the two?
I'm tired of replacing parts, at great expense, only
to get the same result, a persistently reoccurring error
code and a check engine light. I need to start thinking of
getting the car smogged in December or dump the car. I
should be putting money into getting the body work done and
painting it. All that would be a waste, if I can't continue
to drive the car because of a check engine light.
