Ticking from right side airbox
equiprx
Someone suggested the Supplementary Air Valve is causing the
noise. Does noisy indicate imminent failure? I can't hear it
while driving. Only with the bonnet up and my head under the
hood. Could this be responsible for a FF 44 code.
The FF44 code refers to the O2 sensor failure. In the parts manual assembly drawing of the O2 sensor, the same page shows the power resistor. What is the relationship between the two?
I'm tired of replacing parts, at great expense, only
to get the same result, a persistently reoccurring error
code and a check engine light. I need to start thinking of
getting the car smogged in December or dump the car. I
should be putting money into getting the body work done and
painting it. All that would be a waste, if I can't continue
to drive the car because of a check engine light.
Deleted member 8987
On several other forums, I have said (and been yelled at for so doing), unless you know the vehicle, the systems, and what exactly codes mean, all you've done by buying a code reader is to support the code reader manufacturer.
If you take it to a shop, THEY have a code reader, probably better than you can afford, with data stream capabilities.
You're going to have to take it to them anyway, so avoid the reader.
O2 sensor "failure" can be a rich injector(s), vacuum leak, corroded plug, all that and more.
At least it used to be.
If your reader says it has failed, period, okay. If you're just getting a code for O2, look further.
We used to have breakout boxes, pin outs, voltage readings at pins, all that stuff, kinda like a Sam's Photofact.
No idea on the clicking, but I did read that reply on the other forum.
Dave
E
equiprx
Dave
Dave,
This is an OBD I system, so there are no readers other than the Jaguar PDU that the dealers used to have. However, I do have 'on board diagnostics' which gives me the error codes and I have the error code list to let me know what it means.
So far, I have changed out the O2 sensors, both cats, found some vacuum leaks, changed the plugs, wires and cap and rotor. I have installed a number of new ground straps and cleaned out the throttle bodies. The o2 sensors are working and I changed out the ECU. No where does it mention in any of the literature any relationship to the power resistors but they are on the same assembly drawing as the o2 sensors. That is what is puzzling me. What relationship, if any, do they have to the O2 sensor.
Deleted member 8987
Power resistors.........memory banks.....used to be Injector related.
Had a bank of them, one per.
You changed the O2's, still have O2 failure readings?
Deleted member 8987
Okay, take your emissions analyzer, warm it up, place the probe in the tailpipe, and record the readings you get idling and at oh, 2500. This will tell us rich or lean, since the system you have doesn't seem to have data stream capabilities to read real-time data from the O2 sensors.
What you are looking for is low or high, as in way off the scale, that is outside the range of adjustment from the sensor.
I am guessing a 2003 works somewhat similar to the last EFI and computer systems I worked on, what, 12 years ago?
Deleted member 8987
If we can't read data stream numbers on O2 levels, see the shift back and forth to know where the centre point of the sensors are, cannot read if lean or rich (actual) and by how much in the pipes, I suppose we are right back at throwing parts at it.
Michael J.
What model year and what model are we discussing?
On my 90 V-12 XJS, the auxillary air valve is a a 2" diameter solenoid valve that only works when the air conditioning is turned on. It adds air to raise the idle when the load from the compressor drags the idle down.
What does the noise sound like? If hissing, it is because air is sucked trough the 5/16" tube. Try listening with the air on, turn it off and see if the sound goes away.
E
equiprx
It's a 94, XJS, 6.0 liter v12.
The noise sounds like tapping, coming from the passenger side air box, not from the air pump, head, cam covers or intake manifold, thankfully. I have not tried to see if the frequency changes with revs. I did pull the auxiliary air pump relay to disable the pump but that had no effect.
jessebogan
How about an exhaust leak at one of the manifolds??
E
equiprx
Jesse,
I've thought about that, but it's ridiculous trying to get in there to check.
That is one of the things that would result in the FF 44 engine light code.
It would also fit in with my theory, that it was something the transmission mechanic did at the time it was rebuilt, since that was the first time it came up.
I can't see any obvious signs of leakage like a sooty connection.
Things are so tight down there I can barely get my hand to it let alone around it.
Will a standard leak detector react to an exhaust leak?
jessebogan
How about an emission machine? It sucks replacing exhaust manifolds and/or gaskets. I have plenty of 5.3 manifolds, not sure if they are the same... I use a short little Mercedes tool kit wrench to get to some of the bolts way in the back. There is so little room to manuver a wrench there, and that works OK.
maynard
I remember reading that some 6.0 engine have a ticking because the tappet gUide was a little oversize. The article said it wasn't something to be concerned about.
E
equiprx
This noise is definitely on only one side. Does that still fit in with the tappet guide issue?
Went back under the hood to see if I can get more information.
The frequency of the noise changes with an increase in the revs.
The noise is more pronounced with the air cleaner off.
Michael J.
Pull the cover and filter from the right side air box. The Auxillary Air valve plugs into the R/H air box from the backside toward the front. There will be a hose running from the valve to the R/H intake manifold. There are two wires that connect to the valve.
Run the car with the air conditioning on. Is the clicking present?
Turn off the air conditioning. Is the clicking present?
Disconnect one of the two wires to the valve. Is the clicking present?
It is an electrical solenoid. When open, it adds enough air to overcome the amount of RPM drop that occurs when the air conditioning compressor is engaged during idle.
You can tell if it is open by placing your finger tip on the tube sticking into the air box.
What your problem sounds like to me is that the solenoid is rapidly opening and closing due to a poor connection or because the valve is failing. If that is what is happening, you should be able to feel the solenoid clicking.
Does the problem occur when the engine is cold, hot, or both?
Cutrog1 Fuel Pump Ticking Austin Healey 13
warwick-steve Ticking fuel pump Austin Healey 7
D Ticking noise when driving Austin Healey 8
vette Slow Ticking Pump Austin Healey 19
M Fuel Pump Ticking Austin Healey 7
AH67 facet fuel pump never stops ticking. Austin Healey 6
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
B New fuel pump - loud ticking, now fuel spraying! Austin Healey 33
Paulus Ticking noise from car when driving Triumph 7
C TR2/3/3A Right oil Triumph 8
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
red57 Steering not right Austin Healey 66
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T TR6 grinding right rear wheel Triumph 22
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Rut TR4/4A Nice project for the right person Triumph 0
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
D BJ8 pulls right on hard braking? Austin Healey 4
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Popeye TR4/4A Seats - left/right Triumph 8
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
Simmo TR6 Right Hand Drive conversion Triumph 5
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
S TR2/3/3A right to the wheel well Triumph 10
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
Got_All_4 TR2/3/3A 2 questions; raising the body and taking out that lean to the right Triumph 12
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
S TR4/4A water pump doesn't feel right Triumph 2
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
trrdster2000 GT6 Where to find the right tire? Triumph 8
5 Right Up Our Alley Spridgets 0
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
B BN2 First right hand drive model car number 16 Austin Healey 4
