catfood
Was there any form of return spring fitted to the throttle levers other than the springs fitted on the ends of the carburettor throttle shafts? These seem a little weak to return the throttle pedal given the complexity of the lever mechanism on the RHD cars. One of the levers on my car (the one going from bulkhead to carbs) has a small bracket on it at the carb end that looks like it could have had a spring hooked in but there is no obvious place to connect the other end of a spring. Originally the car had a mackled together spring mechanism that is obviously not original.
Cheers
Cheers
