Hi Jman! /ubbthreads/images/graemlins/thumbsup.gif
[ QUOTE ]
1. In the VB catalog it says you need an oil cooler w/ the oil filter conversion kit, are they just trying sell a cooler or is this neccessary?
[/ QUOTE ]
Don't "need" an oil cooler for street motor.
[ QUOTE ]
2. is there a secret to getting the cork oil pan seals to seal or is there a better gasket to use? Mines newly rebuilt and dumping oil.
[/ QUOTE ]
Like others, I would suspect PCV. But to answer the "secret" question /ubbthreads/images/graemlins/grin.gif: For the cork strips, soak in oil overnite before installing. Do NOT trim.
For the pan. I use a THIN film of black RTV on both side of gaskets. As has been mentioned, pan flange MUST be flat!! Also, you do need the elongated flat washers (see Moss Item #24 on External Engine page. I can get seperately. /ubbthreads/images/graemlins/grin.gif) Ref bolt torque: Factory says SIX foot/pounds!! After all, it IS a 1/4" bolt!! Ditto for timing cover 1/4" bolts with the others 12 lbs/ft.
[ QUOTE ]
[3. Is there an aftermarket fuel pump that I can run? my origional is leaking and makes a lot of noise. I am changing to neg. ground
[/ QUOTE ]
Why not just follow K.I.S.S. Rule and get new Neg. Grd. SU?? /ubbthreads/images/graemlins/confused.gif
Any further questions, please write me direct at
ed@justbrits.com !
Ed
