TR3driver
Great Pumpkin - R.I.P
Hmm, come to think of it, many years ago the family wagon didn't want to idle even though it ran OK at higher rpm. In that case, the problem did turn out to be points adjustment. Apparently I had wiped off the point cam with solvent during a tune-up, then forgotten to relube it. The dry cam had worn the rubbing block until the points almost didn't open at all.
Also, when I was having trouble with valve recession on the 3A, that was the symptom that said it was time to run the valves again. The engine would first idle rough and then just refuse to idle even though it ran well enough at higher rpm.
Neither of those seem particularly likely here, just thought I'd mention them as possibilities. Easy enough to check.
