Thread lock vs Anti-seize
bash
I am rebuilding the suspension on my TR6 and have been looking around at various websites for advice and tips. I am from England, and always used copper grease on threads to prevent anything seizing - that seems to be the common wisdom of old car people over there. Americans all seem to advise using some sore of thread locking compound on those same threads. Seems odd to me.
I know that copper grease on threads will give a different reading on a torque gauge, but I never use one anyway (I probably should, but I was brought up with the advice that "Tight's tight, too tight's stripped and slack's no good to nobody"!). I have never had any problem with a copper greased bolt coming loose (touch wood!).
On the other hand, I have had such trouble getting some of the old bolts out that I can't imagine any need for thread lock. Surely that would increase the likelihood of breaking the bolt off in the future?
Sorry for the long post - any advice and thoughts appreciated!
Dave Russell
Yoda - R.I.P
[ QUOTE ]
I am from England, and always used copper grease on threads to prevent anything seizing - that seems to be the common wisdom of old car people over there. Americans all seem to advise using some sort of thread locking compound on those same threads. Seems odd to me.
[/ QUOTE ]
Thread lockers & anti seizing compounds are used for two different purposes. It would seem odd to me also. Can you give specific examples? The only ones that comes to mind are on some shock absorber mountings the bolts tend to work loose & thread locker is sometimes used. Splined hub adaptors are another location where the nuts tend to work loose. There may be a few other specific locations where experience has shown a tendency for fasteners to loosen & thread locker might be used.
Bruce Bowker
Thread lock is to keep nuts or bolts in place so they won't vibrate lose. Kind of a glue on the threads so to speak. Anti seize is used for exactly what it says.
I have high pressure compressors and use both depending on location and need. In one case the 4th stage piston is bolted to the top of a guide piston and no way do I want those two bolts coming lose so there, thread lock is used.
On head bolts I use anti seize so they won't seize up on me making it hard to remove them when necessary.
I have one anti seize compound that is black. My nephew has a can of really sticky gray stuff that is great also.
Bruce
bash
bash
Thanks for the replies. Typically I can't find the references I was thinking of when I wrote my original question, but I definately saw, for example, people stressing that you must use thread lock with caliper bolts in one place, and anti seize on another site. I think I will just do what I used to do, I was just curious why the difference. It was a real hassle to find a tin of copper grease in America - I wound up getting it from a marine chandler 1500 miles away. I wish the factory had used some on the bush sleeves, though - it took me a long time to get the rusty bolts free!
ChrisS
Fel-Pro / Loctite C5-A is a copper based anti-seize as well as Bostik Never-Seez. Both should be available from industrial supply houses, but probably not the local hardware store.
As far as what to use when that is a lot tougher. A properly prepared fastener tightened to the proper torque should not need a thread locker. The problem we have is that we don’t usually have those conditions when we’re working on these cars. Thread locker helps mask our mistakes. I generally use anti-seize products everywhere they are exposed to weather and thread lock compounds that are exposed to ‘excess’ lubrication (set screws on the forks of a transmission). One thing to be careful of is mixing the two. What I mean is putting anti-seize on the shaft of a caliper bolt and thread locker on the threads. Now matter how careful you are they end up getting mixed and you end up with a false sense of security.
Bawanadic
Just wanted to point out that there are different anti-sieze componds made for different hardware material.
I don't use the copper based with stainless steel hardware and I've been told not to use in on aluminum hardware either.
I usually antiseize any part that I don't want to get a hernia taking apart and locktite any part I don't want to see passing me on the highway.
I also really like the new locktite stick applicator and don't forget there are different grades of locktite including the blue and red.
G
They say Harly Davidsons don't use enough Locktight on their stuff. In fact the moto is if something falls off, don't turn around. They'll be another one up the road!
Gary
Dave Russell
Yoda - R.I.P
I think moly disulfide comes as close to being a general anti-seize compound as anything. It works well on all materials. I have been using the same 10 ounce can for the last 45 years & still have a lot left.
Keoke
Well Bash, the copper grease you are refering to is not really a grease at all.The product in the UK as well as here in the US is called "Copa Slip" excellent material for controlling rot/seizing in nuts and bolts.Thread locker is an entirely different product, it can be likened to a glue which comes in a variety of strengths and tends to lock the fastener in place and is also used in conjunction with the split washer. Several penetrants are available here that loosen siezed fasteners allowing the fasteners to be removed more easily. The product I prefer is called :pB Blaster --- /ubbthreads/images/graemlins/cheers.gif---Keoke
A Do I need thread lock? MG 5
fmichaels thread lock Spridgets 12
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
C My 2500M progress/questions thread TVR 5
JFS Wedge Stripped gearbox filler hole thread Triumph 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
charlie74 Wanted Thread restorer kit Triumph Classifieds 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
J TR2/3/3A such strange thread on gear shift knob Triumph 12
J Thread Locker on Shock Bolts? Austin Healey 19
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JPSmit Spridget thread question FORUM Navigation Questions 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
Editor_Reid Parts List Thread Now "Sticky" - parked at the top of this list of subjects Austin Healey 0
Boink Rolls-Royce head replacement thread... Other British Cars 0
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
rvm Annulus shaft thread measurements? Austin Healey 12
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
nevets How do I unsubscribe to a forum thread??? FORUM Navigation Questions 2
B General Tech Waking up a sleeping car thread MG 1
JimLaney Anti-seize or Thread locker ? Spridgets 2
W TR2/3/3A Glaciers move faster - my build thread Triumph 0
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
B Stripped Thread in Gas Tank Austin Healey 26
J anybody tell me why this thread closed? Austin Healey 4
T TR2/3/3A Another wheel bearing thread Triumph 5
Boink Waterless Coolant - thread from the AH forum Spridgets 18
Rut TR4/4A steering shaft/nut thread size Triumph 5
Editor_Reid New "Parked" thread at the top Austin Healey 0
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
B TR2/3/3A end of me water pump thread Triumph 2
Elva164 Michael's Vintage Racing video thread! Racing 5
