GT6 These sills have been replaced, correct?
TuffTR250
I don't have a GT6 but normally Triumph used spot welds. However, I don't see a problem with those. Of course that would mean it was really not "rust free" over it's life time
Regards,
T
tdskip
Hi Bob - my thoughts as well. They were done a long time ago, and seem solid now, but inland California cars don't generally need replacements there.
I also found cracking behind the passenger door at a weird spot. Any ideas on what would cause cracking here? That door fit looks a bit pinched to me too, no?
trrdster2000
tom, reach under the car on each side under the door and back, or get down and have a look. Lots of folks do the outside, but very few do the inside. I can normally feel holes even with gloves on.
Wayne
JerryVV
Those spots almost look more like a braze than a weld, can you check for a brass color? That would be a dead giveaway as I don't believe these were ever brazed, spot welded yes. Interestingly I did find some brazing as original on my 4A on the very front of the front fender around where the grill ends fit to the fender contour. There may have been some brazing on the lower valence too.
Andrew Mace
It all looks about right to me. You don't usually see those extra "brazing lumps" on the older cars, but you do on the "squaretail" models. As to the cracking at the base of the "B" post, I wouldn't worry about that, either. Given that the car seems to have had a rather indifferent repaint, that could just be filler cracking a bit. I suspect that, like the sills, there's a bit of brazing at the base of that post, which would have been "factory"!
glemon
I don't recall for sure, but they may not have spot welded at the upper inner part of the sill you show. I have chiseled off two pair of these by hand now, you would think I might remember. I just took the inset on the front fender (very front) off an original TR4A fender. It was most definitely brazed on. But I don't recall seeing much brazing elsewhere on these cars.
The rocker looks like it is installed pretty well from what I can see. That gap at the back with the rear fender overlay is hard to get right.
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
TomMull galvanized sills for Plus 2 Elan Lotus 10
J TR2/3/3A Replace rusty sills? Triumph 10
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
F TR4/4A TR4 inner and outer sills Triumph 2
W TR2/3/3A Fabricating inner sills? Triumph 39
R 100 Sills / rocker panels from Lynn Cline, Classis Collectables Austin Healey 3
S TR2/3/3A tr3 inner sills Triumph 21
Xte BJ8 sills aluminium and draught excluder Austin Healey 0
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
oxford kilmartin sills Austin Healey 1
S inner sills, outer sills, a post...where to start? Spridgets 28
W Inner sills Spridgets 0
N Aluminium facing on sills and shut pillar, BJ8 Austin Healey 7
Superwrench inner sills Austin Healey 6
T TR2/3/3A TR3 door sills Triumph 2
Superwrench rockers and inner sills Restoration & Tools 6
John Moore Bugeye - Sills or Floorpans first? Spridgets 6
P TR6 TR6 sills/rocker color Triumph 5
longbridgehealey Got the carpet on the sills!! Austin Healey 4
S Help needed- install inner sills,etc. Austin Healey 9
Popeye Painting insides of sills Triumph 11
John Moore Good news on sills Spridgets 3
A Kilmartin Parts [Sills] Austin Healey 5
J TR6 joining the inner and outer sills on a TR6? Triumph 1
spiny Tips needed on cutting out and replacing sills Spridgets 32
G glued sills? MG 17
J What is the process required to replace sills. Austin Healey 1
R B sills MG 4
J How do I replace sills and rocker panels. Austin Healey 1
P floor pans inner sills rockers,outrigers Austin Healey 10
C MGB-GT Painted Sills on 74 B-GT? MG 6
R Outer Sills [ Rocker Panels ] Austin Healey 1
T Question on Welding sills Spridgets 4
J cleaning out sills Midget/sprite MG 0
Hamish Racing TR2/3/3A 3a driven like it’s been stolen Triumph 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
R General Tech Preserve eng/trans that has been removed Triumph 11
kodanja TR2/3/3A Hey Its been a while Triumph 5
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
Rut It’s been nice knowing y’all! Spridgets 13
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
A Spitfire I've been lax on posting - Summer Events Photo Albums - Lots of Pics Triumph 2
D Been waiting for a hot day run Austin Healey 4
Jim_Gruber SUCCESS- VROOM, VROOM has been heard in Beavercreek, OH this evening Spridgets 31
DrEntropy Off Topic Been a busy few months... MG 7
