To Steve Gerow:
So I was reading through this old thread https://www.britishcarforum.com/bcf/showthread.php?90781-Thermostat-questions
because now that I am in Florida full time I think I want to make a thermostat change. Steve, you did quite the job of reporting on various modifications you made. What did you finally end up with? Are you running a 160 degree thermostat, 180 or something else? Fully sleeved/partially sleeved? If you used the sleeve were you able to successfully use a double gasket to compensate for the height of the sleeve rim as well as the thermostat?
Lin
Lin
Hi Guest!
