TR2/3/3A the value of experience when setting timing on a modified engine
GTP1960
"The problem with being ignorant, is your to stupid to know your ignorant" (anonymous )
after several months of continually re-setting the timing & re-tuning my 3A.
Never completely correcting the missing, backfiring, low power condition that I created.
I threw in the towel & trailered my car 120 miles to Charleston Import Automotive. ( highly recommend if you ever need service in Charleston SC, BTW).
Darrel, the owner, turned it over, warmed it up, listened to it run & said " timings way off".
Now I had targeted the OEM spec , ranging between 3-6 degrees before TDC, but because the engine had been modified with an improved cam & over bored cylinders, Those # were out the window.
in short order they found the sweet spot (by ear), then reset valves & carbs accordingly & in that order. He put a timing light on it, just to see where it fell......a surprising 28 degrees before TDC.
He reminded me if you tweak anything in the ignition chain, you must tweak everything & in the proper order. Which of course I wasn't doing.
So the chances of me accurately tuning my car were nil........but of course I was too ignorant to know that.
3798j
Bronze
Good to hear you've got it straightened out. It's nice to have that "go to" guy when stumped.
TR3driver
Great Pumpkin - R.I.P
If it runs OK, I guess that's good.
But 28 degrees of initial timing seems way too high to me, even with a 'performance' camshaft and oversize liners. I think there must still be something else wrong, like the timing mark is not accurate or the cam timing is off or the advance mechanism isn't working right. The stock advance mechanism should be doing an additional 26 degrees of advance at redline; giving a total around 54!
GTP1960
GTP1960
I wondered about that, not that I really understood what I was wondering about,(high tech is a relative thing).
perhaps I misunderstood him.
in any case, she runs better than ever! Wish I would have taken her in sooner.
thx
sp53
That just sounds like way too much, but if it runs good, then good. Just curious, I wonder if you were a full tooth off on the distributor installation, but sounds like they would have caught that. Again just curious, where your vacuum advancement line fitting is? Is it almost parallel with the engine or way out by the fender or way into the block? Maybe a picture of the distributor wires and advancement for my mental records in case I put a big cam in.
Frank_D
If the timing was checked with a timing light at 2500 RPM then the total advance would be what is measured and that should be about 32 degrees give of take. I cannot imagine that the shop was setting a static timing at 28 degrees BTDC. My fresh engine has a more aggressive cam and 89 mm pistons in a balanced engine. The total advance at 2500 RPM is at 30 degrees give or take 1. You are in good order and if the car is running well at all engine speeds that should also be your good feedback.
Frank D.......
GTP1960
GTP1960
SP53,
The vac advance line is close to parallel with the engine, slightly toed out.(I had it pretty heavy toed in before)
the mechanic didn't mention repositioning the distributor, so I don't think he did.
i'll take a pic & send it.
It is running good.......for 45 minute (+\-); then it starts missing at speed.
im going to run it hard tomorrow until it misses, then get a temp. reading on the float bowels & elec. fuel pump to see if it's vapor lock.
thanks for asking.
GTP1960
GTP1960
thanks Frank,
are you running electronic ignition?
also interested in what idle is working best for you.
i don't know for sure what mods were done to mine, as there was no paper trail when I purchased.
So I'm just going by what two mechanics have guessed at.
No Jump Seat
I wonder if the camshaft timing gears are degreed than from factory specs, thus making the timing to "appear" too "Advanced".
"1" would agree that 54 degrees of total timing is WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAY too MUCH!!!
Would be difficult if not impossible to get an engine to fire up with 28 degrees of initial timing!
LarryK
Lots of high HP engines run at idle with 35 deg settings. Maybe chain and crank are set to specs but cam was not set for extra timing. Mod cams are clocked then timing would appear way off.
Frank_D
Frank Here. I have Pertronix points but a conventional distributor that has been rebuilt and calibrated. Idle can be an issue sometimes. I am sitting at 1100 for idle which works well for me. A vernier cam gear was installed with the new cam to assist in setting it up. My mechanic tells me it was worth the small extra cost. Hope it all works out for you.
Frank D........
sp53
It sounds like the distributor is correct; the way I do it is to set the carbs last, so if dwell, timing, valve lash is good, I would be prone towards fuel problem, maybe the coil is arcing off also. I keep a known good coil and put that in sometimes when trying to find a tough problem. I use a stock distributor so I have no advice on the electronic stuff; you will find it your close.
GTP1960
GTP1960
The shop put in Bosch platinum plugs.( im not a fan of) I found the front two were fouled & had a coat of black powdery carbon, the back two seemed fine.
therefore I'm thinking the front carb mix might be to rich. I've leaned it out (3 flats) and advanced the vacuum timing a little & will try it again tomorrow. Also ordered the old champion L87yC's.
here's a pic of the distributor alignment.
thanks for the help!
AltaKnight
The mechanic probably meant the timing at full advance is 28 deg, probably at about 3000rpm.
mine is about 32deg total advance at that rpm and I have a non-stock camshaft
TR3driver
I used to be really fond of them, as they seem to last almost forever.
Then I had one where the gap mysteriously disappeared, and discovered that the other 3 all had the center electrode moving out of the insulator.
On the black plugs, it might be worth trying a "plug cut" to see what they look like at speed. Not unusual for those old carbs to go rich at idle (for various reasons), which will turn the plugs black if you've let the engine idle. But, since the mixture adjustment affects the entire range, leaning out the idle mixture can cause the cruise mixture to go too lean, leading to poor performance and overheating.
A "plug cut" is where you run the engine under the conditions of interest (eg fully warm cruising at highway speed), then flip the ignition off while you shift to neutral and coast to a stop where you can pull the plugs. That way, the plug reading is not contaminated by what is happening at idle.
GTP1960
GTP1960
I will try plug cut, just to get a S.P. reading. But I think I'll wait until my replacement plugs arrive.
I can't even see the electrode on those bosch. it looks like a ceramic cone.
Interesting thing is, is that it started missing and cutting out after it's completely warmed up and running along at a good speed in 4th.
I pulled the plugs and torched the carbon, brushed and replaced. adjusted the mix (2 flats) and it ran fine for about 20 minutes, then intermittent cut-outs.
I pulled the front two plugs again, they were not as black, but not grey either, and re-cleaned. plugs 3 & 4 look good, so i keep thinking my problem is with the front carb..........but maybe it's something else.
GTP1960
GTP1960
Thanks Alta,
you are probably right. I'm going to have him clarify, especially since it's not running as well as it was from just a few days ago, when I left the shop.
TR3driver
Normally that's right. The center electrode is entirely inside the ceramic insulator, and is very thin (like a thin mechanical pencil lead). But on these plugs, it had somehow come loose up inside the plug and extended out of the insulator towards the ground electrode.
The front plugs being black does sound like a mixture problem, but I doubt that is the cause for the intermittent cutting out. Generally once a plug is too carbon-fouled to run, it just quits working altogether. I'm thinking you're more likely to have a problem on the low-tension side, like maybe a ground or point lead that is broken internally. (Assuming I recall correctly that you've tried different points, condenser, coil, cap & wires without changing the problem.) The backfiring also indicates something worse than just timing or mixture.
CJD
Something else to consider when working with "initial" timing settings is that many owners are idling much higher than the factory recommended setting. If you are setting the initial on a running, idling engine, that idles at 1100 rpm, it will be into the advance curve quite a bit compared to one idling at 500 rpm.
GTP1960
GTP1960
ill ck the ohms on my S.P. Lines.
im using pertronix flame thrower,III & new 43k v coil.: but I should try a different coil.
i am running the idle at around 1100. Do you think i need to advance the ignition timing to compensate?
C TR2/3/3A Frame repair and value Triumph 2
D I have doubled the value of my MG Midget. Spridgets 2
AngliaGT 1275 Engine Value? Spridgets 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
HealeyRick Gold Level Concours Value Austin Healey 20
M Original Bugeye steering wheel value Spridgets 3
Kleykamp Rubber bumper Midget value? Spridgets 5
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
J 1963 Austin Healy "Sprite" Value Austin Healey 7
J MGB 1973 MGB Value MG 8
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
TR4nut TR6 Ballpark hardtop value? Anyone? Triumph 3
D 68 Sprite value - need help Austin Healey 9
TomMull GT6 More on value trends Triumph 12
Brinkerhoff TR6 value of a TR6 factory hardtop Triumph 5
M The value in 5 speed conversion Spridgets 18
7 TR6 help with tr6 hardtop value Triumph 5
B Original Hardtop - Identification and Value Austin Healey 8
C Value of 100-4 heater box?? Austin Healey 2
J TR2/3/3A Dynamic timing value Triumph 5
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
Gliderman8 TR6 Opinions on value of this '76 TR6 Triumph 18
C Color change...impact on Value? Austin Healey 24
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
Jim_Stevens TR2/3/3A OD Transmission value Triumph 3
AngliaGT MGB '67 B - Value? MG 5
T 100-6 Longbridge value Austin Healey 5
2 GT6 69 GT6+ suggested value? Triumph 4
J Value on an original BJ7 these days. ?? 38,000 miles Austin Healey 4
RickB MK1 Midge radiator value? Spridgets 2
apbos Works hardtop. The value of or cars is climbing! Spridgets 11
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
Brinkerhoff Market value for an unrestored BJ7 ? Austin Healey 17
K Value of an early Commission Number Triumph 5
N BT7 Restoration value advice Austin Healey 32
6 any value to this?? MG 2
TR4A_IRS TR4/4A TR4A long block value? Triumph 11
C BJ8 Smoothline top value Austin Healey 9
Marvin Gruber Looking at another 100 6- value? Austin Healey 16
R Fair Market Value Triumph 15
J Things that influence the value of a Spridget? Spridgets 18
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
A T-Series MG TD Barn Find [sort of] value MG 1
Marvin Gruber TVR Value TVR 1
