did you reinforce the front lower a arm attachment points? I couldnt tell and while you are doing the keencerts you should go ahead and get Goodparts CV half shafts, much easier to install while the frame is off. and you wont have the TR twitch anymore. and mights as well send the engine off and have it bored out to 2.7 L , forged pistions, 0- decked, 9.5 to 1 compression, head port and polished, new valves, guided and seals, roller rockers, head CC'ed crank shaft lightened and nitried, main caps align honed, carillo rods, all balanced, block bored for cam bearing, front metal sealing plate, new performance cam, aluminum rear plate, Fedanza flywheel. new clutch and pressure plate,
new wiring harness
transmission uprated and add an OD
whew, did I leave anything out
Hondo
