justin_mercier
Re: The start of something big. Frame off restorat
I picked up the dash tonight after 5 hours under vacuum. In order to get it home without accidentally chipping / peeling the veneer, we taped the boards around the dash in place for the trip home.
At the back of the glove box you can see where just a little glue has seeped into the edge between the lid and the frame, the wax in here lets the glue peal right off. I scribed as deep a line as i could from behind with a razor blade between the two pieces.
I then trimmed with a razorblade as much excess material as I could from the edges, so that when handling the dash I would not catch a piece of loose veneer and damage it before it's finished. On this side you can see the veneer tape used to hold together the bookmatched pieces prior to adhering the veneer to the dash.
Using the lines that were visible with the dash flipped over, I finished cutting out the glove box door. I'll have to use more or less the same technique to cut out all the other holes as well, slowly and carefully. Once all the holes are cut out, I'll then go around the edges with sandpaper and round out and smooth out all the transitions, so that there's nothing that can catch and tear.
To remove the veneer tape, you need to apply water. I used a sponge to get the tape saturated so that it would pull away. The water will cause some warpage of the veneer where it's not attached to the dash and there's nothing supporting it behind, but that's ok because those areas will be cut out anyways.
The bookmatching was done so that there would be a whole lot of figure in the glove box area which is the largest unbroken surface on the dash. This is going to look wicked nice when finished.
The next steps I need to do are first finish cutting out all the cutouts and then sand all the corners to finish the fitting and shaping. When that's done i will paint on a light layer of wax-less shellac to fill in the pores of the wood, and then sand it down smooth with extra fine steel wool. Finally for the finish I picked up some marine varnish, designed for outdoor use with built in UV protection and completely waterproof.
