The first line or bottom on the dipstick would indicate a low oil level but anything over the top or second line would indicate an overfill situation? The reason I ask is the last time I changed the oil I overfilled the crankcase but figured it would be OK. Come to find out that the overfill caused a build up of pressure in the crankcase causing the oil pan seals to leak! I drained the oil back to the 2nd mark. Our cars are not like the engines on older American iron where a little overfill is harmless.
