Is there a set length in inches that this rod should be if everything in the linkage is set up properly and the slop in the joints has been fixed. Also what adjustment would need to be made if the link rod hits the firewall before it should....adjust the link rod at the firewall or adjust the lever(81) and link assembly(83) at that end. Does the link assembly have a spec for length as well?
