PatGalvin
Hello all
So, I finally pulled my engine to fix the rear seal leak. I had installed the Land Rover lip seal conversion kit that requires machining of the crankshaft.
Separated the tranny from the engine and pulled the flywheel. Seal looked pretty good but there was oil around the area where the felt seal was installed and oil around the area where the oil pan meets the sealing block, below the seal. It was leaking but I'm not certain if the leak is from the felt seal or oil pan.
Well, I have a new lip seal from RevingtonTR, so I might as well install it. And seal up everythinig even better than last time.
I flipped over the engine on the stand and pulled the pan. Now, I had run this engine for about 30 minutes to set the initial tune, when I put it on the chassis about 18 months ago. I found an oil emulsion in the bottom of the pan, indicative of water contamination in the oil. See photo.
So, you can all imagine my disappointment. I need to address the rear seal area oil leak, but more importantly, I need to address the water in the oil.
I had the block and head magnafluxed and crack checked at the machine shop, so I don't think that is the problem. Head was skimmed to ensure it is flat. Can you guys give me some ideas on the approach I should take to diagnose and fix my "water in oil" problem? I'm thinking head gasket or seal under liners, but wanted to check with you all. My compression was great and engine ran like a champ, for the 30 minutes of testing that I did.
Thanks for the tips. Much needed and appreciated.
Pat
Pat
