Had an Oldsmobile Cutlass Supreme that one had to remove the passenger side front suspension to get to the alternator (FWD). I think it was our VW Passat wagon that had the thermostat in behind the water pump.
Another fun task (two tasks) I had to do recently on the Z4: First, to replace the water pump requires that you unbolt the engine from the motor mounts and, with large block of wood on the left side of the oil pan, jack up the left side of the engine several inches. This is necessary because they put a steel cross member (impossible to remove without removing the entire front clip) directly in front of the water pump. So, you must jack up the engine several inches to allow the pump to be withdrawn past that cross member. Then, I had to replace two simple plastic pipes that ran to/from the heater core because they both were leaking. Sounds easy enough except that you have to first remove the intake manifold to gain access to those pipes and getting that manifold off is no trivial task!
I got a quote from the dealer to do all the stuff I ended up doing myself (water pump, heater pipes, all new hoses, thermostat, new coolant reservoir, etc) and it was well north of $3000! I did it all for about $300 in parts and lots of cussing.
