George Zeck
Hi All:
I am trying to resolve the last thing I have not touched in the car since obtaining in ~ 2001. A working fuel gauge. I was never able to get the right sender / fuel gauge in sync with each other. I've seen the frequent list of gauges floating around here and it was just beyond me. Sorry, electrical is my weakest skill.
I bought a Tank's Meter Match (aka MM) and there claim to fame is to get any send working with any gauge. It's ~ $85 and I thought I'd take a gamble. I have a great ground from the take + MM. From the MM Instrux, it can hold 5 different wires.
1) Keyed Power
2) Ground
3) To Fuel Gauge
4) To Sender (on my car - it's the green with a black stripe wire)
5) Alarm (hahaha)
Has anyone had success / failure with this?
I have 1-4 hooked up and of course am confused as our gauges have two wires to it: sender wire (green with black stripe) and a solid green (???). My gauge, FG2530/70, has 3 connections. When looking at the back of it - RH side has two very close together connections and the green / Blk wire was connected to # 2 spot. The solid green is connected to the LH side. Nothing ever worked reliably. To me again, it appears most other cars have a single wire to their respective fuel gauge and we have two. Again, electrical is not at all a strong point. Prior to the MM, the unit did register what I believe to be accurate from full to half way then zeroed (empty) out the rest of the way.
With the Tank's - The car's Green / Blk connected to Tanks # 4 spot. And no matter where I put the Tank's # 3 wire to the gauge - no signal. In all fairness - I did rough it in to see if I got a signal and I did receive a slight signal (not much gas was in the tank so I believe to be reasonably accurate). I put the wires more cleanly and I got no signal after that. I still have power and I am afraid I cooked the Tank's board based on 'actions' (on in-actions), I just don't know when I connected the power to anything other than spot # 1. Nothing hollered problem along the way (pop, smoke, etc).
Does anyone have any experience with this and the two connection setup. I'll try calling, but everything is 'installation specific' so I thought I'd try here first.
Thanks.
George+1964 AH Sprite MK2
1) Keyed Power
2) Ground
3) To Fuel Gauge
5) Alarm (hahaha)
Thanks.
