Suspension Bushings
DJThom
Does anyone know of a chaper source for polyurethane suspension bushings than the usual suspects?
Will the Triumph Spitfire bushings from Moss work for the front? What about the rear? Will another LBC universal type work there?
thx!
Darren
Platinum
As far as I know, the front A-arms are Spitfire size. Rears are similarly sleeved in steel, not sure what they're from. 1.385" O.D., 0.441" I.D. (approximate), and the outer sleeve is 1.250" L.O.A. Inner sleeve is 1.488" L.O.A.
The OEM part has: "EX31525" and an "AR" in raised lettering in the rubber.
Hope that helps, Darren. If you do source 'em, please let us know who/where?
/bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Platinum
Is that info of any value, Darren? Three days and no feedback is disconcerting. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
DJThom
Sorry, typically avoid surfing at work, and have been busy in garage at home. I called a Lotus parts supplier and they said the OEM type bushings are nearly equivalent to the urethane. A big change when you upgrade a soft MGB, but the Lotus OEM bushings were already quite stiff.
This is a project for next winter, just thinking about it a bit now. I need to do my MGB while I'm at it...
Platinum
No big thang, just used to a more rapid response from BCF posts. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I understand perfectly. Don't endanger your job with trivia!
These rear bushes I have are NOS for the Elan, I measured 'em for ya in case you were on a "hot" mission. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif They are REALLY stout, steel inner and outer shells. I wasn't certain just why you'd look for a poly substitute, but figger'd it'd be something you may use to source 'em by size. I'd be concerned with replacing the originals with something stiffer as the increased shock could introduce some detrimental frame stresses. My frame is cracked at the lower diff "steady rods" mount point just due to my heavy right foot over the decades. The Thompson plan for re-enforcing the standard frame is my "Next Order of Business".
I'll keep digging to see if I can find what the bushes "cross" to. It'd be good info to toss in the Wiki as well.
DJThom
A full and complete cross reference on all parts would be super helpful. I know San Francisco Lotus Club website has started this to some degree, but it doesn't cover everything.
Platinum
Yup. Lotus West had a fair one back-when as well, but so far I've not seen that on line. Can't find my copy of it in this pile I call home, either. But I live in hope. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
J TR2/3/3A Suspension bushings Triumph 0
J TR2/3/3A Suspension bushings Triumph 3
P Installing suspension bushings Austin Healey 5
S suspension bushings Austin Healey 2
ahealey1004 how to remove front suspension inner bushings? Austin Healey 6
G Front Suspension Bushings Question MG 3
tomshobby Which front suspension bushings? Spridgets 15
kennypinkerton Suspension bushings - how many? MG 4
kennypinkerton Replacing Suspension bushings... MG 6
Atrus A few rear suspension Q's [springs & bushings] Spridgets 10
jlaird Oh me, The post on front suspension bushings Spridgets 7
vping Need Tips on Replacing Rear Suspension Bushings MG 7
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
J Poly suspension bushings MG 7
J front suspension bushings. - how big of an effort? Triumph 19
jlaird Question, suspension bushings Spridgets 24
N Front End Suspension Bushings MG 7
jfslenes Front Suspension HiPo Bushings Sunbeam (Rootes) 1
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
P Suspension upgrade for a A40 Devon. British Motor Corp 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
L TR6 MII Suspension Triumph 6
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
M TR6 suspension puzzle Triumph 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
