sqbsprite
I finally got back to my suspension rebuild. I did not get much done during the Holidays. What I thought was a good repair to the diff mounts turned out to be not so good. The welds were OK but sloppy. I spent some time reworking them to be smoother under the rubber mount.
![IMG_20141220_163939_173[1].jpg IMG_20141220_163939_173[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27166-292a5c1ba70e79292728976c93b760a9.jpg)
The bead of weld on the RH side was directly under the rubber mount. I also found a shop to weld my trailing arm that was cracked.
![IMG_20150103_122630_386[1].jpg IMG_20150103_122630_386[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27167-e4828574ca7c3c32ba608f565aa1cf43.jpg)
We added a gusset on the back side.
![IMG_20141227_143816_901[1].jpg IMG_20141227_143816_901[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27168-4e1deb3e79870153fd057dba54733cb4.jpg)
I glass beaded the arms and painted them silver using Rustoleum industrial aluminum coating. It looks like bare aluminum.
![IMG_20141219_160300_768[1].jpg IMG_20141219_160300_768[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27169-d418e4421187ec781cad69dfbc921e36.jpg)
Here is a photo showing the new adjustable mount compared to the old. The bolts that hold the bracket to the frame are actually a little longer, so there should be no problem adding additional shims for toe-in adjustment.
I have the differential installed and next weekend I hope to get the trailing arms back in. I am going to take time to clean and paint the springs and brake backing plates. I had already rebuilt the axles last year, so they still look good.
Hi Guest!
![IMG_20150201_141828_046[1].jpg IMG_20150201_141828_046[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27334-d30f378d788271b25e40224638bdd04b.jpg)
![IMG_20150201_141514_273[1].jpg IMG_20150201_141514_273[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27337-0bbea8518c220584e568c22d99567453.jpg)
![IMG_20150201_141912_303[1].jpg IMG_20150201_141912_303[1].jpg](https://www.britishcarforum.com/community/data/attachments/27/27338-0123dcc38645f7a109d81d666ebb96b1.jpg)
