trboost
Hi Al,
Let's start,
The unit I have is the original VIS, Vintage Induction Systems kit. This was manufactured by Peter Boutcher in NH in the middle to the end of the 1990's. I have mine since about 1998. It was originally tested on Peters TVR (TR powered) and another guy , Nick Formica in Conn. They were co developers with Peter eventually manufacturing the units. Peters hope was to sell the design to one of the big three British parts houses but that never happened. The kit lives on from a machinist in the Bronx N.Y. names Sal Vespertino https://www.triumphowners.com/381 . He has pretty much duplicated the VIS kit. This is the kit that Bennet French sells.
I am using a narrow band 02 with a K&N AF monitor. I have a wired port & plug it in for tuning, other wise it's left home. My current needle is a UVP. The MSD boost retard is probably more necessary with boost over 10lbs but it's cheap insurance. I keep it set to take out 1/2 deg of advance for every lb of boost. I still use points but the MSD only needs them as a trigger. The dwell is now controlled by the MSD AL6. Timing total advance is set to 34 deg mechanical with 15 deg dynamic. I have this thing about getting stuck on the road. The MSD can convert back to points by switching 2 wires, I still use the original mechanical fuel pump & the original fan with an electric back-up for hot summer traffic jams.
The compression is stock 8.5:1 using a Felpro head gasket not copper. The reason I set all the tollerances tight is because a boosted motor will increase compression rapidly looking for the weakest point in the motor. Past oil rings, valve guides increasing the effects of blow by. My first engine suffered from that, this one is perfect after 25-30 thousand miles of abuse. At sea level 8.5:1 compression turns to aprox 13.70:1 using 9lbs of boost. The beauty of this system is that it's momentary, power on demand. I run stock compression around town. Cast iron block & head handle it well.
Cam bearing are not a must. I did it because my oil pressure was low in the original block & the first place to loose it is in the cam bores. I use Mobil 1 15-30 & oil pressure above spec.
Performance needless to say is way better. Remember, we are still talk'n 152cu straight 6. Relaxed 0-60 5.5, 1/4 mile (no hole shot 14.5. I'm sure more agressive driving would yield lower numbers but it's not a dragster (not to say I'd turn down a stop light chalange) . The goal here was to modernize the performace while still staying reliable. The most noticable change is the torque. I'll take torque over HP any day. The car has the ability to pull hard from any rpm in any gear.
Feel free to post questions or call or PM. I love this stuff.
cell 516-250-9345
I
Let's start,
cell 516-250-9345
I
