Trick6
I am planning to build, on paper, two supercharger modification programs consecutively. I am doing this to identify and itemize each component and its cost. One program will be the multi port fuel injection and the other will be the single SU carburetor version. The multi port FI will require a lot more stuff.
My question is how come these after market carbureted supercharger magic kits allow the use of the hot air from the engine compartment, with a forward radiator air intake option, and all the DIY and production supercharger systems incorporate an external air intake plus the intercooler? Something is not right here and I have not started the research yet. When ever you compress air, you are heating it aren’t you? I believe you compress air, cool it, mix it and then inhale it. Not bring it in (hot or mild), mix it, compress it, and then inhale it. That is pushing in hot air directly from the compressor. That outside (cooler air) pick up is a waste of money with this system. I am sure that you are bringing in cooler air then the engine bay air, but you are heating it up again when compressing it.
Is there a system out there that is using the supercharger, carb(s) and an intercooler? I would like to see that.
