59triumphtr3a
Recently received new Tenax pegs for my steel TR3A windshield frame. I notice that the stud part is not completely threaded. The threads do not go all the way to the backside of the hex part that butts against the frame itself. When I screw these in the frame, part of the stud extends into the glass channel. This leaves about 1 turn of thread holding the peg to the frame. (To avoid interference with the glass, I suspect a bit of the stud will have to be ground down.) Anybody have issues with so little thread holding the peg? Strip out? I'm not sure if the threads can be cut further up the stud because it looks like the diameter of the outer edges of the threads are wider than the diameter of the unthreaded shank. I couldn't tell for sure. Anybody have experience or comments with these?
Thanks,
Thanks,
