TR2/3/3A SU Upper jet bearing position
TRclassic3
I've been fighting an annoying leak on the front carb. Made multiple attempts to remedy using the existing cork re-soaked in oil, new cork soaked in oil, "leak proof" O rings. I think I have finally defeated it by using 2 O rings at each packing point. Question is this, the upper jet bearing does not come up to even with bridge. I believe it used to, or at least closer to it, but I don't see any reason that it would not now. I should also mention that I replaced the upper jet bearing, brass washer, the jet tube and the needle as part of my effort to resolve the leak. Thoughts?
charleyf
Ed,
Did you keep the old jet bearing that you removed? If you did then compare the length of it to the new one you put in. Does the jet come up above the jet bearing (to the floor of the carb body) when it is adjusted all of the way up? Short of a different part being used or the possability of having left an extra washer with the upper jet bearing your possbilites are few.
I would guess with the double O rings that your choke is really hard to use.
Charley
titanic
Beware that anything that moves the jet bearing to a lower position will lower the jet and make it impossible to get the mixture lean enough.
Berry
TRclassic3
TRclassic3
Thanks for the feedback. I do still have the old bearing and can compare. Interesting thought about an extra washer...if that exists it would have to be stuck up in there. The jet will come up to at least level with top of bearing. Interestingly, the choke is as easy if not easier to pull than when using cork.
Berry, yup...that's my concern.
TRclassic3
TRclassic3
Charley hit the nail on the head...some how had managed to get an extra washer on top of the upper bearing. Removed and reinstalled and things seem good...AND NO LEAK.
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Rut MGB 62-67 upper MGB steering shaft MG 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
P MG TD Bonnet Upper Sections MG Classifieds 0
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
R TR2/3/3A Upper Wishbone Bushings Triumph 12
L TR2/3/3A Upper steering column bushing Triumph 8
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
D 62 tri-carb upper fulcrum pins Austin Healey 4
J TR4/4A Upper steering flex coupler Triumph 4
R TR6 Body Parts Source, Upper Midwest Triumph 6
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
J TR4/4A confirm upper wishbone arms Triumph 11
KVH General TR Upper Control Arm Reversed? Triumph 5
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
vickxxx TR2/3/3A Upper cylinder oiler Triumph 8
B TR2/3/3A Upper Control Arm - which overlaps which? Triumph 2
GTP1960 TR2/3/3A Tire condition, upper side wall splits...dangerous? Triumph 12
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
S TR4/4A Reversing upper fulcrum link Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
Morris OOS Upper Link Spridgets 6
T TR4/4A Upper steering column Triumph 3
G TR2/3/3A Steering Box Upper Bearing Race Triumph 1
C Sway bar upper installation help please Austin Healey 3
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
V Upper Ball Joints Triumph 16
B Upper radiator stay rods black or body color? Triumph 11
bcbennett '74 upper radiator hose Triumph 5
T TR2/3/3A TR3A upper windshield seal Triumph 12
I TR6 TR6 upper A post seals Triumph 0
T TR2/3/3A TR3 upper A arm bushings Triumph 6
D MK2 upper radiator hose question Jaguar 3
K loctie upper rod bushings Triumph 4
memphis Door Panel - Upper Piece? Austin Healey 8
JPSmit fixer upper Spridgets 5
Morris Upper link triangulation Spridgets 0
Steve An Upper-Crust Spot Today Spotted 4
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
Tinkerman TR 3 Upper Column Felt Bush Triumph 7
jerrybny Upper C arm resistance Triumph 4
bigjones Upper Ball Joint Fun and Games Triumph 15
