[ QUOTE ]
Later pumps had a vent in the cap and in the body that were hooked together with tubing.
Regards, Bob
[/ QUOTE ]
Hi Bob,
Do you know why my AZX1319 pump has a permanent cap on top with a ball check valve in it? It lets air out only. There is also the bottom vent hole as normal. It appears that it is designed to intentionaly pump air through the pump body. Something to do with clearing the ionized air around the contacts, cooling, or?
Thanks,
Regards, Bob
[/ QUOTE ]
Hi Bob,
Thanks,
Hi Guest!
