SU Mix Adjust Memory Refresh
Platinum
Yup. From the underside a clockwise turn is leaning the mix (by raising the jet).
TR3driver
Great Pumpkin - R.I.P
:iagree:
Afterwards, I always push up on the jet a little, just to be sure it's still in contact with the nut.
K
karls59tr
Come to think of it I've heard that mentioned before but forgot to push up on the jet.....what could happen if you neglected to do that?
Platinum
Sometimes the jet can be "grandfather'd in" by gunk. Pushing it up just insures the spring has had enough oompf to overcome any stuck condition.
TR3driver
Otherwise, you turn the nut a flat or two, which isn't enough, then you go another flat or two, still not enough, then some more ... by the time I realize that the jet isn't moving I've forgotten where I started.
Platinum
:lol:
PC eclectic mix Spotted 1
K SU Carb Mix...Air filters on? Triumph 4
A Need help diagnosing fuel mix problem Triumph 23
S Picklex20 and por15 don't mix MG 1
aeronca65t Interesting mix of cars Other British Cars 18
VelodromeRacer Mix screws for 1966 BJ8 carbs... Austin Healey 7
T FYI - Carb cleaner and IBM laptops don't mix Triumph 5
G T-Series MGB steering column features-mix/match? MG 3
B MGB MGB body mix? MG 11
sparkydave Help! Oil and brakes don't mix Spridgets 18
aeronca65t Mix of Cars ForSale Other Cars 9
kindofblue Antique Pllanes and Cars do mix Other Cars 11
V Dual exhaust must mix Triumph 10
G HD8 Idle Adjust Screw Austin Healey 10
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
V 89 XJ6, How to adjust front camber? Jaguar 2
T TR4/4A adjust fuel level Triumph 8
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
gbtr6 TR6 Valve Adjust, What clearance? Triumph 5
bighealeysource Best way to adjust doors Austin Healey 9
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
J TR2/3/3A steering stops , how to adjust Triumph 2
S Clutch self-adjust? Austin Healey 28
S Adjust mixture on a BT7 Austin Healey 9
T SPQR Tappet adjuster, Click Adjust Austin Healey 1
H Stromberg Carb Sync and adjust Triumph 6
B Adjust headlights/ "true" them? MG 7
M How often to check/adjust valves? Triumph 7
B Triple carb setup too rich? How to adjust? Austin Healey 3
memphis Torque Head Bolts & Adjust Valves Austin Healey 13
W handbrake adjust Austin Healey 2
T looking for valve adjust shortcut. Triumph 33
QuickSilver I Need An Alternator Adjust Bolt MG 0
K TR2/3/3A TR3: carb adjust mixture ie. how many flats... Triumph 12
T Bonnet Latch Adjustment [how to adjust bonnet latch [BJ7] to keep it closed] Austin Healey 14
F Hydraulic clutch adjust Triumph 9
Pythias Click Adjust? Spridgets 6
MTribe how to adjust static timing? Triumph 8
bluemiata90 Wedge TR8 adjust cold start idle and warm temp idle Triumph 3
Luke_Healey How to adjust rich SUs Spridgets 7
C TR6 Proper way to adjust front hubs, TR6? Triumph 13
6 How to Adjust Voltage Regulator Spridgets 0
jlaird How to test and adjust a fuel gauge Spridgets 25
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
W handbrake adjust Austin Healey 1
H How to Adjust Valves in 100-6? Austin Healey 10
KLUTZ Will this door corner somehow adjust in? MG 11
L KYB Gas-adjust shocks Triumph 1
